spddmon
i just did my fork seals in order to remove the damper retaining bolt on the bottom of the forks to keep the damper from spinning i welded a 16 inch long square tube to a 1 1/16 sockett
That works too. I just skipped the socket and only use the wand.WRFF,
welcome to the group.
Here's a pic of the "tool" I made.
I used an impact tool to loosen and remove the allen screw.
Hope this helps.
JimView attachment 35460
