AIS removal.... missing plug in the clutch basket
O.K., been asking a lot of questions.... little response. Anyone do an AIS removal? Anyone have a video..... tanks gotta come off? How about installing a +4 advancer.... need to drain the oil?
Tank has to come off, coolant drained, and radiator removed. If you use the Ivan's kit I believe your headers need to be removed. If you use holeshots they do not. For the timing advancer, just put it on its kickstand to make sure no oil runs out, but you will need a gasket for the cover.
If you're buying the holeshot kits they come with very detailed instructions.
Thanks pal!! Anything special to keep gas from flying all over when the tank comes off?
You could just remove the front bolt of the tank, lift if up and hold it there with a prop rod if you don't want to remove the fuel lines. It makes removing the pipes easier.
