Bar risers First-Gen
Does anyone know of a Yamaha OEM handlebar riser to fit a first gen FZ1 that will result in placing the stock handlebar about 3/4” closer and a half-inch higher? I like the stock bend, if it were just that little bit closer.
If not an OEM solution, is there an accessory riser on the market? Thank you.
Hi , I have a 2005 fz1 . I wanted my stock bars a little higher & a little farther back then you are wanting .
I ended up buying the Power risers from POWERMADD .
https://powermadd.com/street/risers/powerrisers/
While installing them I became aware of endless positioning options by rotating the risers & or the bars on the risers . After a few rides & minor adjustments I was able to find the perfect sweet spot for me .
Also https://roxspeedfx.com/ have a few options
