Delta
Hi guys just a quick one.
I’m wondering if any of you have had this noise..
So the bike runs ok through the gears, up and down etc.
When I’m stationary and pull in the clutch and put it into 1st gear it’s fine. When I start to let the clutch out as the load goes on and the bike starts to pull away, I get this chiff chiff chiff sound with the rpm. Sounds like a rubbing or scraping going on. Could it be the clutch release bearing? Once the clutch is fully engaged and I’m pulling in 1st gear the noise stops. Any ideas, have you had this, what was the problem or cure?
Just want a few ideas before I take the clutch side case off.
Thanks guys.
Delta.
Thanks guys.
Delta.
