clutch
john t
going to replace clutch on my 58 plate fz1s can anyone recommend a good clutch kit also does anybody know torque settings for clutch spring bolts ,thanks.
No idea on the clutch kit but the tightening torque for the spring bolts is 10Nm/7.2ft-lbs. If you look up the service manual for the fz1 on manualslib (dot) com, all the specs are pretty easy to find.
Be careful on those bolts. If you don't have a high quality torque wrench that has been calibrated, I suggest about 6.9 for those. I broke one once before the wrench indicated 7.
