Earth points
Hi guys
Can someone tell me where the earthing point is from the wiring harness on a gen 2 please, I've got the main one on top of the crank case , surely there is another that earths the harness only it I can't see it ,
Regards Dale
Just a little update taped in the loom I found 2 x 6 pin female connectors that have a plate inserted to connect all the earths together , once I managed to get it apart I'm sure I've found the problem. I cut the connectors out and soldered the wires together in groups of four and added a tail to each which I have then bolted to the engine earth point .hopefully were done
I'd like to know where you put the all your grounds, I'm in the process of putting my bike back together. I would be greatly appreciate it.
Sorry I've only just seen this, I soldered tails on to the earth wires and bolted them on the crank case with the main earth strap
