Easily fill coolant overflow tank
You find yourself with 'missing' coolant and need to add water or something to your overflow tank on the road on your Gen 1.
Easy way = remove the triangular shaped right-side cover, remove the overflow tank cap, take your side cover and turn it up so it is now a hollow boat-shape, position the mounting bolt hole over the overflow tank opening, and pour what you need into your "funnel".
Done. :cheers:
