spyd3rm4n
I previously had an issue where the bike (2004) would idle and rev fine, but as soon as I tried to ride it would bog/sputter badly when I gave it throttle. I found water in my fuel system so today I got all of the water out, got the tank perfectly clean and made sure I got fresh clean fuel out of all the float bowls. Installed new spark plugs, did an oil change, and coolant flush too.
Today I started it up and it idled fine and revved in neutral without any issues. As soon as I took the bike off the center stand and put it in gear it started intermittently sputtering again just like before. This time it was dark out and I realized the entire dash was flickering, like intermittent complete loss of power.
I thought maybe a dead/weak battery so I swapped it with the fresh battery on my 2002 FZ1 which I was just riding last weekend. The problem is still there with the new battery.
Could this be a sticking kickstand switch or a faulty tipover sensor? The mechanical part of the kickstand switch was gummy and not moving freely so I lubricated it and it now moves smoothly when I raise and lower the kickstand, but I don't know about the contacts inside. My next step is to bypass the switch (disconnect the switch and use a jumper wire.)
Has anyone had these issues before? What else should I be focusing on? I checked the infamous white connector. It isn't melted but there was some minor corrosion - a white coating. I sanded the pins and sprayed some electrical contact cleaner on them.
UPDATE - I think it was a corroded electrical connector. Several of the connectors with the heavier gauge wires (power) had some visible white and bluish crust on them. There's a bundle of connectors under the tank and the red one had a few pins that were really bad. Sprayed with some contact cleaner that was recommended by a guitar guy and upon reconnecting everything today the bike starts and runs great now.
UPDATE 2 - Problem is back, this issue is happening more than before and almost left me stranded at work. Updated post below.
UPDATE 3 - Seems to be running great now. The fuse on the starter solenoid was loose and one of the blades was worn. If you remove this fuse there's no ignition power.
