JayredZ1
My front brakes are really touchy I barely pull the lever and they start grabbing the problem I have with this is I have to pull the brake quite a bit before the switch engages and triggers the tail light and at that much pull I would be doing stoppies every time I came to a light or slow down, my rear brake engages fine but I don't always use my rear brake and I'm worried about someone behind me not noticing me slowing down because my tail light not engaging, the switch trigger you can hear it tick when I pull the lever far enough so as far as I can tell it's not a faulty switch I have crg levers just wondering if anyone else has this issue and if they have a solution, I don't hardly have any free throw in the lever before engagement, if I only had like another .075 -.100 thousands of an inch worth of travel it would be no concern. Any help would be appreciated.
