niceast
Looking for some feedback front forks options except Öhlins. Please share the cost also.
(correct me if im wrong)
result from searching forum were 04 05 06 07 08 r1 forks with brakes calipers, wheel, and axle. (fz1 master is compatible r1 brake lines?)
I have to replace one cracked all the way around at the base
What about the 09+ r1 forks or fz07, fz09, fz10, mt07, mt09, mt10 are those compatible?upper clamp diameter = 50mm
lower clamp diameter = 54mm
inner tube diameter = 43mm
wheel axle diameter = 25mm
wheel axle float side = 31mm
fz1 travel = 130mm
r1 travel = 120mm
