B17NN H
flashing??
hi pal..
I had a mechanic change the plugs for me but I’m not sure if he did a resistance check (probably not)
How was your bike acting after the 2 coils went?
hi pal.. the bike starts up first touch of the button doesn’t stall/cut out once started.
revs fine from stationary all the way to redline, but under load at around 7000 rpm it kind of holds back. It’s as if it’s being starved of fuel after 7000 rpm.
Im gonna put some fuel treatment in it and clean the fuel pump filter this wk end hopefully.
