Tommo
Hi all.
Not long had my 2006 FZ1N, was forced to put in the lower octane fuel as we had an issue with petrol stations locally. Filled the tank and set off. After a couple miles the bike started jerking violently and the popping from the exhaust on overrun stopped. I pulled into my mates garage, dumped enough fuel to get me to the nearest station and filled with high octane.
Issue resolved for about 30 miles then when the tank was near empty it started again.
Removed and fully drained the tank, removed the fuel pump and washed out. Cleaned the gauze out too.
Refit everything and refilled with high octane.
Rode about 60 miles, no issues at all until I pulled into the fuel station. Didnt fill up as they didnt have high octane. Started the bike up and immediately stalled. Struggled to start but when it did start it cut out constantly. Limped out of the fuel station and the jerking began. Cutting out at junctions. 60 mile ride home and it wasnt as violent but the jerking was prominent.
Few weeks later rode 20 miles, no issues. Stopped for half hour rode home again no issues.
Last trip out, 30 mile trip through a roads, hit the town centre and 10 mins later it started again. Limped it to the garage and it hasnt moved since.
Previous owner had no issues and neither did I till I noticed it after the low octane fuel situation.
Issue does NOT happen at WOT. Only seems to occur when idling, or gentle riding. Low revs etc.
Tank has been off a few times since, pipes not kinked.
Since then I've removed the Ivan's FCE and checked battery and connections - all ok.
Fuel tank vent tubes all ok.
Following is the mods I'm aware of.
Mods:
Delkavic exhaust slip on
Ivan's FCE (now removed)
Remap (unsure of where or what kind)
AIS still intact
Air box still standard
Possibly only when engines warm however first ride with troubles, I'd covered 1 mile to fuel station then 2 from there before issue started.
Engine light comes on when its jerking. I had codes 14 and 19 prior to the fault from the FCE. Now I have code 20 after the last fault.
Anyone come across something to give me pointers?
Hopefully that's enough info.
Many thanks
Mods:
AIS still intact
Many thanks
