Gauge cluster problem
Hi all,
Maybe someone has faced a similar problem?I've attached link to a video so you can understand.Sometimes everything is fine for months,other times it turns off/on like this every ride.Contacts on the gauge cluster back I have checked and cleaned,but it doesn't really help.
https://youtube.com/shorts/szZ1je4wJr4?feature=share
Maybe , if you haven't already, try some electronics spray cleaner. Remove the instrument cluster, take the back off and I'd spray the circuit board(s). Check the male, female plug in connections going to the cluster, there could be some corrosion. And spray them to. Check see if there's a fuse Check for corrosion. Check for loose connections in the circuit cause thats what it looks like to me. Good luck
