Dante
Hi there
I bought my second 03 FZ1 a month ago with 6500 miles (the previous owner kept it 'garaged' and given the mint condition I bought it after a short test ride). I have another FZ1 with 100,000 miles so I knew what I was buying.
But then my problems started.
It had a rough idle followed by a low rev sputter (bad MPG included) There's basically no performance below 5000 rpm and its not great above that either. Honestly my 100,000mi bike runs better than my 6500mi bike.
So I've spent the last month troubleshooting a few things I've read here and following the manual but so far my issues are still here.
I've done/checked:
-Redline carburetor cleaner
-Fuel injector cleaner
-New spark plugs/air filter/fuel filter
-New rectifier/regulator (a local shop said it was getting low charging voltage)
-Both coils tested ok (factory spec)
-No vacuum leaks (spraying cleaner arround the carb joints)
-TPS angle adjusted (factory spec)
-Carbs removed and cleaned (no re jet at this time, I can pull them out again if needed)
Jets cleaned (sprayed/brushed/wired)
Float height adjusted (factory spec)
Diaphragm in good visual condition
Synchronized after assembly (4 Gage synchronizer)
I noted that:
A small o ring under the vacuum cap on one carb is bigger than the others (could be pinched between cap and diaphragm)
One of the spare plug caps leaks considerably and reads below the 10 ohm specification (The spark
jumps to the block through my finger)
Any other ideas?
I know how spare costs and where to get them but Id like to go slowly. I find more satisfying troubleshooting myself and spending money on tools and spares than paying to a shop to do it
Thanks
I've done/checked:
I noted that:
Any other ideas?
Thanks
