Guidance:)
Hi folks, long time reader here. I have 2003 FZ1 since 2003 "B" I believe I read
I've had a couple boo-boo's that required a period in healing. Recently I got on with some i.e. "Ivan's, kits upgrades, all has gone well until now
On the right side of the radiator "" where does the Carburetor Hose connect
(5/16? hose below the fill cap)
I enjoy coming daily, reading about each :)adventure, discussion, thought
When I feel I have something to add:) I will participate.
Thank You in advance
Craig
The plumbing mess is removed, carbs with "Ivan's kit".
Radiator flushed
Stock Filter
New Dunlop. Q2's waiting to be put on (Cycle Gear promotion winner:)
Oil Change next
Haven't considered "Slip On"
You can see it in this shot however you can't see the connection point on the radiator. The nipple that this connects to is on the right side of the bike. It's just down about two inches from the top of the radiator.
Assistance?
Not to doubt, I thought this hose connected at the radiator inlet, then connects to vacumn @ #3 carb?
the hose is actually to small ? Id ?
Just trying to be sure
Thank you for the welcome, thanks for "lightening response":)
I almost forgot, Ivan actually did the carb "bypass" on my bike when he did the jet kit so mine may be routed differently than stock. I will post the other diagram from the manual which shows the stock configuration.
