Darieonp
I have a 2002 fz1000 and I replaced the neutral safety switch first because the neutral light wasn’t coming on I changed it and it came on I turned the key on and hit the button and pull the clutch and it crunk up(the clutch is in a million pieces btw inside the clutch cover but it would only crank if I pulled the clutch) I moved the bike to a more open area crunk it up but after 4 to 5 second the bike shut off and now it won’t Crank from the button so I jump the connection between the two starter Seliond it truns over but will not crank everything works fuel pump coming on an every light on the dashboard of the bike come on and do there job I took the spark plug out to see if it was firing and I’m not get a spark or anything plzzz help idk wat else it could be
