oxlotts_FZ1
New to the FZ1 forums!
I recently purchased a 2013 FZ1 with 75,000 miles on the clock (1 month ago). 4th owner. The second owner did around 55k on the bike. I purchased the bike, had absolutely no issues (I did oil change & coolant flush). Commute 60 miles a day for around 2 weeks. Then, I took it to Vegas (300 miles or so). After that trip, the bike dies at low rpm. I was stranded and left the bike at a mechanic (well known in LA). Air filter was clogged. Fuel filter (in tank) was rough (very dirty). They replaced those items, checked compression, checked plus, checked coils. All checked out all good. I picked it up, ran great for a few days. Now back to the same symptoms. I have only been using 91 Octane out here in CA. I am assuming the bike had a valve adjustment at some point, but I have no paperwork. The bike fires up normally, but dies between 20 seconds and 1 minute. Sometimes as soon as I put it in gear. No check engine light.
I know I am knew, I looked a lot on the forums already, but nothing seemed super applicable. A lot of Gen I issues. Any advice is appreciated! I heard it might need a valve adjustment but others said no, it wouldn't start if the valves were too tight. Not really sure. Trying to avoid the mechanic: "throw parts at it" but maybe thats what it needs?
