How To: Roth Velocity Stacks Installation
First of all they are beeeauuuutiful!
Stock: They are 65mm tall.
Roth: They are 30mm and 70mm tall. http://riperformance.myshopify.com/products/velocity-stacks
  1. Remove the inner fairings, tank cover, and lift the tank
  2. Remove the airbox cover lid. Don't forget the center screw.
  3. Remove the stock stacks and take out the screws from them.
  4. First loosen the Roth stacks from their bases enough so that the base sits flush and tight in the airbox.
  5. Screw in down the screws but don't tighten them completely.
  6. Screw in the stacks so that they seal the inlet flush. This can be felt by your finger.
  7. Now tighten the base plates completely.
  8. Now tighten the stacks completely. You may need to 2-3 tries between this and previous step to get an airtight seal between the base plate and airbox bottom and the stacks and the inlet sides.
Let us know what you think?, any real performance gains?.
Dyno runs are about $75 for a baseline run with an O2 or 4 gas reading. It's nice to compare from mod to mod to know if you're on track with tuning.
I am liking the look of this mod! Just a quick question. I have so far decatted with a Mivv slip on and Pipercross filter. Modded the air box and have on order some flies. Will the bike to too lean now?
