It won't start.
Hi. I have an FZ1 2005 which will not start. The motor turns over, but will not spark. The tacho flicks to 9, which means something. Does anybody know what? Andy Bray
Do I didn't. I have owned it from new and if I had not ridden it for a while it takes a bit and gets going. You are right, I'll check to see if there is spark.
Thank you for your reply. Will check in the morning. Andy Bray
Hi Kluejr. I had a few craft beers and good news. I pulled two plug leads off to check the spark and it started on two cylinders, leaving a charger on. I think the problem is that I did not buy a Yuasa battery to replace the last one. The Yuasa battery normally lasts me 6 or so years and is a bit stronger than cheap ones. There is a problem with the EXUP, due to the tach contantly going to 9, so I will ride the bike to the Yamaha shop, instead of it being towed. Thanks again for your advice as it got me to get the bike running. Andy Bray FZ1 2005 Australia.
