Marquis
Hi.
My 07 fz1 s has developed a fault. I first noticed the problem on the way back from doing the NC500 in Scotland this past summer. On the long trip home the low beam lights kept cutting out, Not ideal on a dark motorway. I switched to high beams then back to low beam, It was ok for awhile but then cut out again a few times. I've checked bulbs fuses and relays, they all seem fine. I think it has to be a wiring fault. I've had problems in the past with the headlights but found a bad connection on the connector near the left indicator. (fully faired version). But I found those easily enough and crimped the wires together remote of the connector. Has anyone had a similar problem and found a solution? any thoughts on where I should Look would be very much appreciated.
Thanks in advance.
Thanks in advance.
