Low beam works whilst running, pass light works but no lights on highbeam?
Volgen83
Joined
Mar 16, 2018
Messages
4
Location
Bristol
Visit site
Hi, scratching my brain abit.
was riding home a few nights back and needed to turn on my high beams, flicked the switch as you would normally do and headlights died, I had speedo lights and everything else.
Tried again, still nothing so quickly tried my pass switch, this worked so had to ride the section of road with pass pressed until I hit a better lite section of road.
Bulbs obviously are ok, checked, cleaned and dia-electric greased the connectors on the harness (left hand under front fairing).
next I'll check the grounds and probably strip the front fairing off to get to the relays.
I automatically assumed the switch was dead in the switch gear, so have sourced a replacement, plugged that in and no difference.
Wondering if anyone has experienced anything similar etc, abit of insight or more knowledge than myself.
