new member 2002 FZ1
John Todd
hi I have been riding for 50 years, owned quite a few different bikes, but this is my first litre bike. It had been sitting about 8 years, and the carbs were gushing fuel out. I took the carbs off, cleaned them, found that the float levels were all over the place. Don't know how that happens. Put them back and to my surprise she fired right up. Went through the bike, changed all the fluids, followed the shop manual for maintenance, put on some new Michelin Road 5 tires, and licenced it.
Well it is quite a bike, I can't believe the power, on the throttle she just wants to leave earth and head for the moon. I don't feel any of the famous lean surges I've read about, but what I do notice is that she doesn't like a light throttle, bitches and grumbles and snatches especially in lower gears. Behaves just like an air cooled Ducati in fact, the bike I was on before the FZ1. I'm wondering if Ivan's kit cures that condition, or if that is something you just get used to. Also it has a giant Yoshimura can on it that does a lot of popping on decel and light throttle. So looking for any suggestions on how to make it run better. I don't know what if anything has been done to the carbs. The air injection system has been removed and it has a K&N filter inside what looks like a stock air box.
Another noise I hear seems to be from a gearwhine in the transmission, not a bad sound, but quite distinct during decel. The bike has 22,000 miles and feels pretty tight.
DaveC
Not sure about the carbureted bikes, but blocking off the AIS on the 2006 and up models stops the popping on deceleration.
I used some Youtube vids to figure out how to just plug mine instead of installing block off plates.
rdcusmc
Ivan’s will help - a lot. You should see improvement across the board after install.
I’ve done the full gamut of mods and did before and after dyno runs to measure effectiveness. I recommend Ivan’s jet kit, the air box mod with new filter, porting the boots as easy items to wake the engine up and make it more responsive and pleasant. I also installed a thinner Cometic head gasket to raise compression, cleaned up the head flashings with a Dremel and hand timed the cams after installing adjustable cam gears. It is all documented in the FZ1OA website in text and photos.
All together I added 12 hp at the rear wheel. Dyno shows 140hp at the rear wheel now which means something on the order of 160 at the crank. I get fuel mileage consistently in the low to mid 40’s in mixed riding. And the engine is a delight at any rpm.
There are some simple suspension mods you should consider. Recommend raising the forks 8-10mm to get a little more weight on the front end. Recommend replacing the dogbones to increase the effective rate of the rear spring by 20%. The rear is way too soft in stock form. Even better, changing out the rear shock is recommended and cheap. The R6 shock or the BMW shock are recommended (I’ve had both and they are an improvement. I ended up with a Penske and it is a delight but these are harder to find.). The Raven fork mod on the FZOA site is very simple for the front forks and makes a very nice difference for about $30 and an hour or two of your time. Lastly, braided brake lines and upgraded brake pads are cheap but extremely welcomed improvements in braking performance and feel.
Welcome to the Gen 1 world. The bike is stellar even after all these years, even more so with the simple, cheap and very effective mods I’ve described above.
Best,
Ron
rdcusmc
Correction. The dyno charts start page 13 with mods following. LOTS of great discussion through most of this thread however.
Ron
Whip!
Did you write down the jetting when you were in there cleaning the carbs? It might already have the jet kit in it. Most people do that when they remove the AIS and air box. Ivan's and Dale's kits are good and get you pretty close, but sometimes it takes a couple tries to get it dialed in just right. Depending on altitude and conditions... ya know.
John Todd
the needles look stock, compared to the tapers on Ivan's. Anyhow I ordered Ivan's kit today, so will see how things go once I get my hands on that.
Best,
Ron
thanks for the advice Ron.
Best,
Ron
thanks Ron for the advice, I will certainly be working on the carbs again, ordered the kit from Ivan today
John Todd
just to add a note about the type of service you get ordering parts online.
Called Ivan's on November 2 and ordered the carb kit. Spoke with Ivan himself, very professional and pleasant. Parts were at my door in Vancouver BC Canada at 1:30 PM on November 4 via Fedex.
Placed an order with Partzilla on October 19 for the intake boots, throttle cables and carb diaphragms. Threw in the clutch cable for good measure. Next day I got a message saying the clutch cable wasn't available until December. I assumed they would ship the in-stock items and did nothing. Finally called them on November 1st and learned that they weren't going to ship anything until the order was complete. The person on the phone was pleasant and accommodating but really! what customer wants to wait 8 weeks for parts? So still waiting for UPS, Partzilla says they shipped same day (Nov 1) but UPS says they didn't get the info until Nov 2, now they are schlepping my parts around to all their depots in the the eastern US and I'm on the west coast of Canada. The provided tracking number didn't work until I called Partzilla back on the 3rd of November. I want to do the carbs this weekend but looks like it won't happen. I like to ride year round barring ice and snow so this delay is not making me very happy. I'm even less happy when I get a daily email from Partzilla urging me to buy ATV tires, Yamaha hats and shirts and other assorted garbage, just wish they would focus on getting my parts to me as quickly as possible, considering they have had my $450 US in their pockets since October 19.
John Todd
I put the Ivan's kit in over the holidays, today was my first chance to go for a ride. I have to say I'm impressed. The bike starts and idles much better, gear change is much smoother, and although I didn't go tooo fast owing to the chance of black ice the engine seems to pull much stronger and smoother. I have to think that previously the carbs must have been incredibly lean at idle and in the lower RPMs. I still have some popping in the exhaust on decel, but the sound of the engine through the exhaust is much more authoritative. Well worth the time and money to install this kit.
