coolzzy
Hey guys, just picked up a gently used 02 FZ1 with 7800 miles on it. Apart from needing new tires (i believe the BT20 on the front is original), i'm having an idle problem. When I picked it up to ride home, I had to have the choke half on to ride it home just to stop it from dying at every stop light, and even then i had to feather the throttle. So after getting it home and having a closer look i see the idle adjuster screw. But no matter what I do to it, the throttle will hang at 2000-2500 RPM, and if i let out the clutch a bit and then back in, the idle drops to 900-1000RPM and stays till i blip the throttle again. This is mildly annoying when shifting through the gears as it hangs at 3500RPM when rolling so it doesn't engine brake like it should.
So my question is is this just a hanging slide? I put some carb cleaner in the bike because it supposedly still has a tankfull of winterized gas and i'm hoping it will sort itself out. But I'm not sure where to set the idle screw or why it makes no difference when I turn it. I know its connected because I can feel it moving and hear a very slight increase or decrease throttle. A blip on the throttle though will send it soaring and then hang at 3k or 2kRPM until I put out the clutch a bit to return to "normal" idle. It sounds so soft, I can't tell if its running all cylinders at idle, but then I'm used to my FZR which was hella loud all the time.
The bike runs down the road like a rocket though from 2500RPM on up to red though and pulls hard, SO its just an idle adjustment and maybe a hanging slider? I don't want to tear into it if I don't have to but just wanted a second or third opinion. Sorry for the long post, let me know what you think!
