Peter Ward
Hi There
If like me you have found your Fazer a bit lazy in the steering department, i have just discovered a easy fix to increase the rear ride height by 25mm. This will quicken up your steering without being to radical or adding to much to the seat height. The rear suspension link ( long silver arm) from a 04,05, 06 R1 will fit straight in place of your existing arm, as it is shorter than std it lifts the rear up. No need to buy after market lift plates, and your bike will look std in case this is a problem ie Germany.
