rear sprocket
Thank you.
Looking to go to a 47t, but a lot of part descriptions are for 06-09 FZ1.
So thanks again for the reply.
Remember that the a 46 tooth is the largest rear sprocket that will fit, using the stock chain (116 links) and 16t front sprocket. A 47 tooth rear sprocket will work with stock chain,if you use 15 tooth front sprocket. I use a 16/47 combo with a 118 link after market chain. The 46T from the FZ6 will fit the FZ1. FYI
Dave
