reignman
No need to worry, it's isn't an issue with my fz1. My friend has an 01 gsxr 750 that won't start tho. We had just done some work to it (new rotors, integrated tail light, new mirrors) started it up and everything was fine. A week later and now it cranks over but won't start. we checked spark and thats good but the injectors aren't spraying. we can hear the fuel pump cycle and the fuel line definitely has pressure on it when disconnected. I soaked the injectors in injector cleaner over night and still nothing. i put a volt meter up to the injector wiring and it seems to to get voltage to it when the engine cranks. oh btw it does start when spraying starter fluid sprayed into the throttle bodies so im certain that its the injectors. and we put it in dealer mode and it isn't throwing any codes. any help is greatly appreciated. this is my main riding friend so it'll be a boring season if we can't get it going before the weather breaks lol. thanks
