Pyramid Fender Extender
NJFZ1
Moderator
So I decided to install a front fender extender on the bike to keep the header area cleaner. I figured it would also help with keeping rocks and other debris away from the radiator. There are not too many manufacturers of these extenders out there so I went with Pyramid (UK based). Got the part from these guys Jesters Trick Bits. Believe it or not it was cheaper to buy it in the UK than here in the US even with the additional shipping. It came out to $31.97 shipped, but I guess the price will vary a little bit based on the exchange rate when you place the order. Anyway here are the pics of the install:
This what came with the kit. Fender extender and 4 small screws:
Remove front fender. You'll need to remove six bolts (3 per side), which I have circled in yellow. You'll need a 5mm Allen key as well as a 10mm box wrench to hold the nut on the inside of the fender on the back bolt. Should be a 5 minute job at most:
I opted to use a two part epoxy to bond the fender extender to the inside of the fender. I did not want to have to drill my stock fender for the 4 screws. This way if I ever want/need to remove it I can do so and the fender will be just like stock.
Washed inside of fender with dish detergent and roughed up the inside of it and the mounting surface of the extender with 60 grit sandpaper so the epoxy would adhere better:
I left the double sided tape in place to help hold it while the epoxy cured, but in retrospect that wasn't a good idea because it didn't allow me to move it around to get the best fit.
Finished product:
Don't worry if you get a little epoxy on the paint. It will not really adhere since it's a slick finish. I got a little on there and it came right off with some spray polish and a terry towel.
Mounted fender:
Shot of whole bike:
Overall I am satisfied with the way it came out, but I wished the fit of the fender extender had been better. Luckily it sits in a spot where a minor misalignment is not really noticeable. I like the matt finish on it as it blends right in with the rest of the black on the bike. I know that Powerbronze (another UK based company) makes a similar product, but theirs is a shiny black.
I like it. Will be happy to hear how much it helps with rocks and keeping the headers clean after a few rides.
Really nice job Tony. I hope thats gonna be a Godsend to those nice shiny exhaust headers. It looks like it should do a good job of keeping most of the debris from both the radiator and the exhaust. Great pics as always. Thats definitely on my list of things to get. Thanks for the write-up.
That came out very good Tony. It blends right in and is almost unseen. :tup:
Yea, that's one of the things I like about it also, how well it just blends in. I think the casual observer will miss it all together on the bike or think that it came like that from the factory. The matt black finish on it is a perfect match to the rest of the bike.
Looking to order this fender extender from Pyramid but couldn't find the exact model in our country. Any idea if the model intended for MT-09 fits FZ 1?
Probably a very good idea to use these. As far as reviving an old thread, IMO it's better than creating a whole new one that regurgitates the same data. Makes searching easier. 👍
I have one on my bike, not rigid though. It made a huge difference when i was forced to ride on a freshly repaved road (tar and peat gravel). The rear swingarm had a few dozen pieces of gravel stuck on it but the header had nothing.
Id rather read though 1 long thread versus several. All the content in one place makes sense.
