Fan ?'s
JJAM
Apr 9, 2011
29
57
Vancouver, WA
Maybe this is answered somewhere but I didn't see it.
Do both fans come on at the same time or are they staged? My left one comes on at around 212 but the right one doesn't. Just asking before I go tearing into the bike.
Thanks, JJAM
Thanks, JJAM
They both come on at the same time. Check the fuse, they are fused separately.
If you are unsure where the fuse box is:
attachment.php
attachment.php
attachment.php
Thank you!! I will check the fuse and go from there. When I got the bike the po had cut the wires on the fans instead of removing the plugs. He thought that the fans needed replaced after the bike was damaged. Not so they just needed tweeked.
Thanks again, Jim
Thanks again, Jim
Most likely if the bike was in an accident, and the fan was met with resistance, it blew the fuse to keep from burning up the motor. Good luck!! :tup:
