joker80
What is the best/most recommended chain lube?
That is what I have been using as well and I agree it works pretty well. I just wondered if there were any real differences between the other types out there.
WD40 works just fine, but the downside is that you have to apply it more often. Also if you get caught in the rain it will wash off pretty quickly. I actually use WD40 to clean my chain and have been using the Bel-Ray lube, but only because I had some left. As Billy said pretty much anything that is safe for O-ring chains and doesn't make too much of a mess is ok in my book.
I always thought WD-40 was notorious for breaking down rubber parts, like o-rings.
I'm using Maxima Chain Wax by Maxima Racing Lubricants. My dealer recommended it. When used as directed, it doesn't throw lubricant off the chain.
I used to use Maxima but I hated the way it smells, and it was always making a huge mess even though I applied it according to the directions.
Why are you smelling your chain? :justkidding: However, did you still smell an odor after the lubricant set-up?
Also, did you warm up you chain prior to application? I use a piece of cardboard to catch over spray when I apply. I notice no fling on to wheels; which I have always had with other chain lubes. Oh, well-different strokes for different folks. BTW, I don't know if Maxima Chain Wax provides extended chain life over other lubes, so this is not a strong recommend, just a preference so far.
I was reading an article about using kerosine, and the article was an interview with the guy who is president of PJ Products, which also has a chain lube in their enventory of products. And 'PJ' was saying how he didn't care for the kerosine in that after it had cleaned the chain, there was a kerosene film. The way I took it was that the chain-lube sprays, and especially wax types which adheared to bare metal, were inhibited from sticking as designed by the 'film' being between the chain 'metal' and chain lube, thuss I took it that it could be flung off the chain surface easier than wax adhesion to bare metal.
I guess what I'm getting out of this is that after you clean with kerosene, it would be advisable to clean off the petroleum base cleaner with a soap based cleaner so as to bave bare metal for the lube to stick better.
I've used PJ's, Bel-Ray, Maxima and others. Put them on a warm chain, after my ride, and let them dry/set-up over night. All of them either flung-off and/or attracted lots of dirt.
Last Fall, I was turned on to this stuff. You can actually watch it clean your chain when you spray it on. I use a piece of newspaper to wipe off the excess, then let it dry overnight. No fling-off, a shiny chain and it does not seem to attract dust. Cheap, too; $5 at Lowe's.
DuPont™ Teflon™ Multi-Use Lubricant
DuPont? Teflon? Dry-Film Lubricants
they sell several types, do you use the chain lube? its actually a wax product. I might have to check that out. I have been a faithful shaft-bike rider for the past 3 bikes at least. I used bell ray before and I have it now but I like what i have heard about the wax-based lubes and as a bicycle racer I used only wax after trying it. great stuff!
