dangerous
My take on it is if your going/is to mod, Ivan`s most likely is the way to go,but if you want to keep the bike basicially stock than someone like ecunleashed may be the preferred way?
I think ecuunleashed and the ecu flash seabass has had are different.
Seabass had his bike flashed on a dyno which is the best way to get perfect fueliing. No 2 bikes are exactly the same.
Ivans way is the best if you keep modifying your bike but it still needs a custom map on a dyno to be sure the fueling is perfect.
