Butthead
Well, it up for its first service, just shy of 1000kms
Great bike, I chose well
Riding position is comfratable and I'm 6'4"
Throttle response, smooth
Seat is out of the inquisition, thankfully when we go for rides there are frequent refreshment stops
Brakes are fantastic,
Front end, fine, rear shock agricultural, riding on bumpy or rough roads or which we have a fair share of here, doesn't absorb the bumps and it puts you off line, but having said that I haven't really played around with the settings too much, plus I'm at 230lbs, its acceptable, and you adapt,
Great power delivery, only experienced to 6K, and that licence loosing, low range is fine, plenty of poke at mid gears and high revs, ( be even better soon)
Fuel consumption is good as I only use it for hills riding and no comuting.
Gearbox clunky, first always , bleeping it through the gears helps, but dropping to neutral/first when slowing down , its vauge and having to slightly let the clutch out to get it to engage. Hoping that a oil change will improve it , if not I'll live with it
OEM tyres are good, grippy, wide tyres footprint is like riding on rails, bearing in mind that my last ride had a 120/80/18
Looks great
Overall very pleased with it,
Looks great
