CaptainAwesome
Looking to swap out my handlebars and trying to make sure I have my ducks in a row before starting.
Plan: Renthal 758 with ~40mm risers. Stock cables
I like the grip location but the angle of the grip is too much for me. I'm OK going a little farther up, but overall stock location is fine, little wider is a plus.
I do not want to change out cables at this time, if possible I don't want to reroute anything either since it's my daily driver and I'm doing this outside unfortunately, so timing is an issue.
From a what I gather this is possible with lower risers as everything ends up pretty close to stock location, just a little bit wider.
And does anyone have any measurements or pictures where you drill a hole in the bar so the controls don't shift? I'd want to have that done before doing this if possible.
