Gen 2 has a center stand as wellSince there is a center stand I’ll assume this is a Gen 1. Which of the three hoses is dripping? The one that is straight cut or one of the two that is diagonally cut. The diag. cut are fuel over flow. I think you’re right that the straight cut is from the top of the radiator cap.
So is the dripping fluid gas or coolant. If it is the coolant over flow then the next step is take of the right fairing panel so you can access the radiator cap. See if the collant is right up to top. Also check overflow tank under the right side cover to make sure it is filled to correct level (about 1/3 full). You may have a bad cap or not.
If it’s fuel coming from the daig. cut tubes that usually happens when you over fill the gas tank and is no big deal.
My respect just went up a couple notches.Gen 2 has a center stand as well
GEN 2's have center stands stock.Since there is a center stand I’ll assume this is a Gen 1. Which of the three hoses is dripping? The one that is straight cut or one of the two that is diagonally cut. The diag. cut are fuel over flow. I think you’re right that the straight cut is from the top of the radiator cap.
