mprtklr
I did a search but still had a quick question. On the digital fuel gauge, the last bar starts to blink which I figure means it is tapping the reserve. However, when I go to fill up, usually a couple miles afterwards, it only takes around 3.5 gallons to fill. I would think if I was hitting the reserve I would be taking more gas. When does the light start to blink? Also, are you suppose to "over-fill" it above the ledge that is in the tank? Thank you in advance.
