Polestar
Wizard
2011 Honda CrossRunner 800
Honda revealed its all-new Crossrunner model at the EICMA Milan Bike Show. Sourcing the 782cc V-Four from Big Red’s VFR800 model, the new Crossunner represents an intriguing streetbike entry from the Japanese marque.
Honda reveals the all-new Honda Crossrunner, an upright standard sourcing the 782cc V-Four from the VFR800.
Honda pitches its new ride as a hybrid model: “Take the flexibility and exciting attitude of a Naked performance machine, and give it the upright riding position and rugged appearance of an adventure bike; what you’re left with is something special. The Crossrunner.”
The Crossrunner utilizes the liquid-cooled, 90-degree 782cc V-Four powering the Interceptor in American Honda current lineup. Peak power claims are 100 horsepower at 10,000 rpm 53.7 lb-ft torque at 9,500 rpm. Honda explains the engine selection thus: “With most sport tourer machines using an Inline four-cylinder engine and most adventure motorcycles using a twin-cylinder powerplant, the design team had an exciting opportunity. A smooth, flexible and soulful 800cc V-Four engine, specifically tuned for a machine that helps a rider find a flowing rhythm.”
Honda’s PGM-FI fuel injection delivers the fuel. A six-speed transmission transmits the power to the rear wheel via chain final drive.
The Crossunner sources an aluminum twin spar frame. Suspension units are a 43mm fork (preload adjustable) and Honda Pro-link a gas-charged rear shock (preload and rebound adjustable). Braking features Honda’s combined ABS, with a pair of six-piston calipers clamping on 296mm front rotors and a 256mm disc with two-piston caliper in the rear.
Honda press touts the Crossrunner’s upright riding position and stability, the marque claiming 120 wind tunnel sessions to “build a motorcycle with such unwavering stability.” The wind tunnel must have shaped the new Crossrunner’s bodywork and upper fairing, with short windscreen. Styling for the new bike carries over the lines teased before EICMA in concept sketches.
A new mid-displacement street bike, Honda's Crossover will enter the European market in 2011.
The folks at Honda have pushed the “cross” prefix hard at Milan, having dubbed its adventure-touring-like concept at EICMA the Crosstourer. Then there’s the scooter/motorcycle “crossover” design study, dubbed the New Mid Concept. Where exactly does the new Crossrunner slot itself in the motorcycle family? We’ll let Honda have the final word, for now:
“With the attributes of both a Naked performance machine and an adventure bike, the Crossrunner is a new kind of motorcycle. One that can effortlessly adapt to many different styles of riding.”
2011 Honda Crossrunner 800 (ED-type) | Motorcycle Specs
ENGINE
* Type Liquid-cooled 4-stroke 16-valve DOHC 90° V-4
* Displacement 782cc
* Bore × Stroke 72 × 48mm
* Compression Ratio 11.6: 1
* Max. Power Output 74.9kW/10,000rpm (95/1/EC)
* Max. Torque 72.8Nm/9,500rpm (95/1/EC)
* Idling Speed 1200rpm
* Oil Capacity 3.8 liters
FUEL SYSTEM
* Fuel delivery PGM-FI electronic fuel injection
* Throttle Bore 36mm
* Air cleaner Oil-permeated, cartridge-type paper filter
* Fuel Tank Capacity 21.5 liters
ELECTRICAL SYSTEM
* Ignition System Computer-controlled digital transistorized with electronic advance
* Ignition Timing 8° BTDC (idle) ~ 50° BTDC (1200rpm)
* Sparkplug Type IMR9D-9H (NGK); VNH27Z (DENSO)
* Starter Electric
* Battery Capacity 12V/11AH (YTZ-12S)
* ACG Output 386W
* Headlights 12V; 55W × 1 (low) / 55W × 1 (high)
DRIVETRAIN
* Clutch Wet, multiplate with coil springs
* Clutch Operation Hydraulic
* Transmission Type Constant mesh 6-speed
* Primary Reduction 1.934 (64/33)
* Gear Ratios 1 2.846 (37/13)
* 2 2.062 (33/16)
* 3 1.578 (30/19)
* 4 1.291 (31/24)
* 5 1.111 (30/27)
* 6 0.965 (28/29)
* Final Reduction 2.687 (43/16)
* Final Drive O-ring sealed chain
FRAME
* Type Diamond; aluminum twin-spar; pivotless
CHASSIS
* Dimensions (L×W×H) 2,130 × 799 × 1,243mm
* Wheelbase 1,464mm
* Caster Angle 25° 45'
* Trail 96mm
* Turning Radius 2.8m
* Seat Height 816mm
* Ground Clearance 140mm
* Curb Weight 240.4kg (F: 115.2kg; R: 125.2kg)
SUSPENSION
* Type Front 43mm cartridge-type telescopic fork with stepless preload adjustment, 165mm axle travel
* Rear Pro-Link with gas-charged HMAS damper, 7-step preload and stepless rebound damping adjustment, 145mm axle travel
WHEELS
* Type Front 6-spoke cast aluminum
* Rear 5-spoke cast aluminum
* Rim Size Front 17M/C × MT3.50
* Rear 17M/C × MT5.50
* Tire Size Front 120/70 R17
* Rear 180/55 R17
* Tire Pressure Front 225kPa
* Rear 250kPa
BRAKES
* Type Front 296mm dual floating hydraulic disc with 3-piston calipers, C-ABS and sintered metal pads
* Rear 256mm hydraulic disc with 2-piston caliper, C-ABS and sintered metal pads
ENGINE
FUEL SYSTEM
ELECTRICAL SYSTEM
* Starter Electric
* ACG Output 386W
DRIVETRAIN
* 2 2.062 (33/16)
* 3 1.578 (30/19)
* 4 1.291 (31/24)
* 5 1.111 (30/27)
* 6 0.965 (28/29)
FRAME
CHASSIS
* Wheelbase 1,464mm
* Trail 96mm
* Seat Height 816mm
SUSPENSION
WHEELS
* Rear 180/55 R17
* Rear 250kPa
BRAKES
