B
Buildercher
Guest
Who has done this conversion form 530 to 520?, any advice as to sprocket combinations? currently i run stock rear 45t & 16t front and like it. Is there much performance and braking gains to be had with 520?.
less rotating mass = better power transfer
as well as increased wear
and yes... I've done it... 15/47 520... just stay away from aluminum on the rear and make sure you keep up with your adjustments...
what make did you end up going for the rear sprocket?
I have 16/47 right now and was considering the 16/47. Is that harder on the bike and will it take a 520 chain? Adjustmenst? Do you have to check it more often?
Driven steel rear 47t & 16t front with gold chain. Will be interesting to feel the difference between 530& 520?. Thanks for the advice
I don't think you are going to feel a difference between the 530 and 520 since you also changed the gearing.
I am thinking about going with 16/47 titaniumII sidewinders with their ti 520 chain. Any negatives to this except money?
Been running a 520 conversion for about 4000 miles with no issues. Rental 16 up front, 47 Supersprox and a Gold DID.
