Aligning headlight on a Naked
Help aligning headlight on a naked
Hi guys,
I need to re-align my headlight. I should have taken a stock setting before upgrading suspension & going to a 55 on the rear, but I didn't think about it until after noticing the headlight points lower than it should.
Can someone with a stock naked tell me the distance from the wall to the front tire, and the distance the light beam reaches up the wall with the bike upright? see pic below
Just finished checking and re-aligning it. The top of the beam was at 50cm!! I re adjusted with an empty tan k to 91cm (top of the range (so with a full tank it should dip to the lower end of the range.
FYI FZ1N headlights has the vertical adjustment on the top and the lateral (Horizontal) adjustment on the bottom knob (Opposite to the faired version).
park 20ft from a wall.
sit on the bike and turn the headlight on, the top of the beam should be 2" lower on the wall than the distance measured from the ground to the center of the headlight
-B
