Dreamdemon
Hi,
today I put a new front tire and realized that my brake pads need replacement. The weird thing is that the inside pad is worn completely while the outside pad still has about 3-4 mm left, never saw something so extreme before. It happened on both front brakes. Usually I would say that the caliper is not working correctly on one side but the same problem on both? Did anyone had similar wear pattern when he/she changed the pads?
