This is a nice question's thread for this site because if ours bike is not the perfect choice if you want be able on weeling,fz1 is perfect for burnouts! Obviously..find a close place like a close hypermarket park,use life end tires,wear all safetly closets ecc ecc..
Now the practice: first be able on stop burnouts..front weel on a wall,stand up on yours feet,than you can be able with gas,brake and cluch..2 fingers on brake,tourn gas with rest of hand,when fork goes down,leave slowly the cluch and when you feel the rear weel starting,more gas and leave cluch totally. Don't use cluch from this moment to don't cook it! This part is not exiting but necessary to feel the rear weel and be able with gas and cluch.. Don't look at dashboard because on movement is better look in front! Now if you have understand the sequence, is the time to try on movement: the bike at 10km/h+/-,you stand up on footsteps with the body
incline to put weight on front weel,open the cluch and squize lightly the front brake with 2 fingers,now gas moderately and little bit cluch..at this point you need to feel the training sensations so play with gas brake and cluch untill the fork goes down and the weel start run.. Now leave the cluch and play only gas and brake to control the speed! Waring: if the rear turn left or right,close gas immediately before louse control!! Better than this I cant explane.. Enjoy your new trick! ;-)
Ahhh the bleach trick and when we could not find bleach good old Tranny Fluid used to make a nice thick moskeeter killing cloud.
Tires were like 30 bucks back then...lol
