thimmesch1
Hi
first of all I just want to say what a great community U have here & thank you for all the info!!!
I bought a 2004 Fz1 that had been sitting for a couple years when you turn on the ignition it would pump gas all over the floor,so I pulled the carbs (incorrectly removed the throttle pos sensor) found 2 of the float valves were gummed up. cleaned out the carb jets etc made sure everything was freed up & put it back together.
Now the bike does not leak any fluids, but when you hit the starter it starts right away but after about a second & a half it sound like it is firing on 3 cylinders ( I turned up the idle all the way & when you hit the starter it revs way up for a sec .5 then goes to a missing idle @ about 1k) so I replaced the plugs & changed the oil, same thing-no improvement ,I bought this from a friend of a friend & they both stated it ran fine before storing it? I found the procedure for setting the TPS but can not get it to idle correctly?
what Next???? any Ideas>????
Thanks
Dave
Thanks
Dave
