Carburetor Coolant Hoses
One of my carburetor coolant hoses has a pin hole leak. The hose I need is the one that attaches to the left most carburetor on the outside of the carb. I was wondering which part number I would need to order on the Yamaha microfiche. I was thinking either number 60 or 61? Thanks!
I noticed that I'm not leaking anymore. It's a common mod. I disabled all of the lines and took the carbs into Napa and matched the plugs up. Just to be safe I added hose clamps. Now I have more room for maintenance.
Do you remember what size vacuum caps you used for this? I checked at my local auto parts store and they come in a few different sizes.
Local Nappa store has the 1/4 inch vac caps, use the small clamps form the stock hose....1/8th caps for the two at the carbs...Did mine today..10 minutes
