fz1n2009rara
Hi everyone
I need some help. Any advice or if you actually know what might be happening and could tell me that would be hugely appreciated.
My fz1n 2009 has an issue with the clutch operation. As the title states it is not disengaging. I've had this issue for a couple of months now and no matter what I do I just don't seem to be able to solve the issue.
So whilst out riding my motorbike the clutch cable kept going slack (ever so slightly at first) so I would just turn the nut at the bar end ever so slightly and it would kind of remedy itself. Until a few weeks ago and my clutch cable snapped so I thought no big deal I'll just replace it. Which I did but that kept going slack aswell. Now it's at a point that I go out for a ride and I need to make big adjustments on the bar end nut to stop my bike from stalling as the clutch isn't disengaging and wants to keep moving even though the clutch lever is pulled in.
I've trouble shooted this and thought that my clutch plates and basket might be faulty so I've taken off the casing replaced my clutch plates and springs and filed out the notches on my clutch basket. I put it all back together in the correct manner, plates all the right way, nuts and bolts all tightened to spec. Casing on correctly. And then I tightened my clutch cable.
I found a biting point. Good amount of free play on the lever. It was clicking into neutral from 1st with ease. Great I thought this has solved my problem. I took the bike for a test ride and 2-3 minutes in my cable slackened off. OK I thought, new plates no big deal. So I tightened it. But then it kept doing it and through out the test ride I had to keep tightening my cable again and again. So replacing the plates and springs and filing the notches has done nothing to solve my problem.
Does anybody think the actuator arm is faulty?
Or could it be something else?
Thanks in advance for anyone who takes the time to read this and reply
