javahaxxor
Wizard
Hi guys,
This is not tried by me personally (yet) but I thought I'd share anyway.
You know the difference between our bike at some pace, and some twisties, and the supersports which almost turn by themselves ? At the same time, the FZ1 has to be wrestled a bit, you have to use your body, you have to countersteer, etc. On a ZX10R 2012, there was no need for that. I just looked at the bend and it rocketed in turning by itself, I just had to finetune the line, almost featherlike steering.
well I met this guy who raised the forks 5 milimeters from their original setting and he said that wrestling is GONE, it behaves just like it should. I realize you're changing the chassis geometry but I can't see where that could cause any harm. I guess what it does is move the weight a bit forward, make the steering angle a bit more agressive and stiffer fork tubes, so less flex at lean.
I'll probably do this mod when the sun kicks in over here
