sirreal1
Recently I've had two problems that are intermittent and I'm not sure what is wrong.
Problem 1: When the bike is running and I put it in 1st gear to go the engine quits...but the kickstand is UP. Sometime it will even go into first gear for a few moments and then the engine quits as I try to go. The kickstand switch looks fine and the spring is strong and it extends all the way out when I put the kickstand up. I don't know why it's doing this.
Problem 2: After running the bike a while then shutting it off for 15-20 minutes then trying to start it, it just turns over fast but won't fire. I work all the switches including the kickstand switch, the kill switch (which I never use) and the clutch switch and after trying to start it 3-5 times it eventually starts. When it does start, it runs rough for a few seconds and does not respond well to applying throttle to rev it up for those few seconds. Also yesterday while riding on the highway at about 70 mph, I went to accelerate a bit to catch my buddy and the engine shut off for a moment. It threw me forward for a second or two then started back up on its own and I kept riding.
This only happened the one time but it is a concern.
If any members have experienced either or both problems, I would sure appreciate some feedback. I take excellent care of my bike and I have never had any problems whatsoever. It always started very quickly and the engine never quit like it did yesterday that one time. Throttle response is smooth and steady.
Info on my bike:
>2008 FZ1 29000 miles
>cat gutted and fitted with aftermarket muffler. AIS is blocked inside the AIRBOX to reduce the "popping" when i put on the DanMoto muffler.
>NO other mods done as the bike is currently under YES Warranty
>oil changed Mobil1 4T and filter every 3000 miles
>use only Chevron 87 Oct gas and never let it get near empty
>spark plugs have about 14,000 miles on them but the first set I changed when I bought the bike with 15,000 miles looked still good.
>also changed coolant when I bought the bike and used Yamaha coolant to refill it so it has about 14,000 miles on it now.
>air filter changed when I got the bike too...used stock Yamaha filter so it now has 14,000 miles on it...check it periodically and still looks pretty clean.
>I don't ride the bike hard...it has never been near redline since I bought it. I do accelerate pretty hard at times but never had it about 9-10,000 rpm at most. Most riding is cruising on highway at 70ish so about 5000 rpm.
>bike is kept spotlessly clean and lubed and never ridden in rain or wetted to wash it except a couple times I got caught in the rain going home.
Can't think of anything else relevant at this time...
Thanks for any feedback.
Glen
Info on my bike:
Glen
