imb4ufz1
Hellow Fellow FZ1 members.
Where do I fill antifrizer?
I flush the radiator over the weekend n fill the antifrez from the radiator cap, but over flow tank is empty. :-(
Then you need to top up the overflow container to the minimum (lower) mark and run it. You may have to add more a second time I suspect.
I bought the $2 transmission funnel after removing that side cover. Pull the back end down (so the rear tire is touching the ground) while on the center stand. If I did not do this, I was over the top line on the over-fill tank.
Deluxe Transmission Funnel
BTW:
Anyone know how often we should flush the radiator system and put in new coolent?
