Eff-Zed-1
For reference, local shop quoted 4 hours on bike, 3 hours if brought just the forks and labor rate there is $120 per hour.
Plus parts of course.
I wouldn’t worry about it. Replace the wear items, reassemble, and fill.Resurrecting this old(ish) thread.
I am replacing the fork seals, Teflon coated bushings and dust seals on my 2005 FZ1 with 133,xxx miles. I've changed them many times over the years. This time I want to clean the insides of the cartridge (if advisable).
I've searched for and have not found any info whether or not to disassemble the fork cartridge for cleaning.
Any words of wisdom?
Thanks.
Jim
I’ve seen a lot of cartridges out of the forks, but don’t remember seeing any cartridges being opened up and disassembled for cleaning if that’s what you mean. If there were anything replaceable in the cartridge I think you would see the parts in the fiche. Makes sense that the cartridge would have some crud in it. Not knowing what’s in there would have me avoiding solvents like brake cleaner. I’m guessing clean fork oil would be the recommended fluid to draw thru the cartridge to flush out dirt.Resurrecting this old(ish) thread.
Thanks.
Jim
Mam you gotta have some serious/competent knowledge on how to build shim stacks. Leave that to your tuner.Diving a little deeper into how a cartridge works, I found this pic:
The stack on the left is the compression assembly in the fork cap and on the right is the rebound stack (in the cartridge).
In this article about fork operation: https://motofomo.com/motorcycle-forks-faq/
I don't think I'll be tearing the cartridge apart.
Thanks.
Jim
