FS: Gen 1 Parts
All parts from a 2003 FZ1 Less than 10K miles
Photos can be found HERE <-------CLICK THIS LINK TO SEE PHOTOS
DIBBS will be based upon date/time of PM as I have these items posted on a couple of boards. Once a PM is received I will reply letting you know where you are on the list for that item as well as post in thread, calling DIBBS in the thread without sending a PM stating DIBBS will not get you in line.
Payment by PayPal or US POST OFFICE Money Order (no parts will ship until payment received - in case of money order this means after the Post Office cashes the money order) NO CHECKS - PayPal please add 3% to asking price to cover PayPal Fee if using a Credit Card OR send funds as a GIFT to avoid fees
All prices are OBO and do NOT include shipping.
Parts will ship from zip code 28105. I have no problems shipping Internationally. THANX
If you don't see a part listed, ask about it (parts I do NOT have: fairing inserts, headlight/tail light, passenger grab rails, passenger pegs, Forks, engine, transmission, helmet lock, ignition switch, airbox, ???)
Silver OEM Front Sprocket Cover $10.00
Lockhart Phillips Signals $10 pair $20.00
OEM Turn Signals 1 set Right Hand side $13 each
OEM Chain Guard $15.00
Full Muzzy Exhaust (Header, mid-pipe, Can) (the can has roadrash) $400.00
Ivans Servo Eliminator $75
Stock Fork Internals $50.00
OEM Brake Lines (front and rear) $15.00
Slider Brackets (needs new pucks) $10.00
Side Cover (2) $20.00
Carbon Fiber Hugger (has two bad spots) $75.00
Tail Section (Bee) (rashed) MAKE AN OFFER
Right side passenger bracket $15.00
Engine Bracket and all mounting bolts $100.00
Front Axle $15.00
Rear Axle $15.00
Battery (have to check to see if it can be shipped) $50.00
Clip Ons w/ Gel Grips $80.00
Ignitor Unit $150.00
Relay $50.00
Tilt Sensor $40.00
Side Stand Switch $25.00
Clutch Lever Assembly $15.00
Kill/Starter Switch housing $25.00
Coils $50 each with plug wires $100.00
Rectifier $45.00
Front Master Cylinder w/ new lever $40.00
Dogbones with bolts $10.00
Battery Leads $15.00
Front Sprocket $10.00
Throttle Cable 1 $7.00
Throttle Cable 2 $10.00
Center Stand (no springs) $20.00
Coolant Overflow with hoses $15.00
Tension Bar (rear brake) $25.00
Caliper Bracket $50.00
Swingarm Relay $25.00
Rear Caliper $30.00
Rear Master Cylinder and reservoir $30.00
Wiring Harness (intact): $30.00
Under Body MAKE AN OFFER
Water Pump $50.00
Coolant Hoses with all clamps $40.00
Fan $50.00
Swingarm Black $100.00
Front Wheel with Tire and Rotors $200.00
Frame (has a small dent and the fairing stays are cut off) with title $175.00
Steering Head Bearings $40.00
Lower Triple Clamp $35.00
Gas Tank Bracket and Hold Down braclet $25.00
Petcock $10.00
Fuel Level Float with wiring $15.00
OEM Headers $75.00
Gas Tank (dent/rashed right side, no rust inside) $65
Instrument Cluster from 2001 (has broken plastic on back side, ODO 65K) $100.00
Front Calipers $70.00
SOLD Upper Fairing (BEE w/ Decals) (small crack) $150.00 SOLD DCrippa
SOLD Galfer SS Braided Front Brake Lines (lower banjo bolts are rusty) $25.00 SOLD Gixxerjasen
SOLD #39 RELAY ASSY 5JJ-81950-20-00 (elec fiche 1) $5.00 SOLD Uncle Alpo
SOLD OEM Turn Signals 1F 1R $13 each SOLD 1slimfizz
SOLD Radiator $50.00 SOLD Bumblebeefz03
SOLD Black OEM Front Sprocket Cover $10.00 SOLD Bumblebeefz03
SOLD Rear Wheel with Tire and Rotor $175.00 SOLD curvecrazy
SOLD Stock Rear Shock (upgraded yellow spring not sure what rate) $75.00 sold Tachypsychia
SOLD Front Fender Black $35.00 SOLD Wraithdogg
SOLD Foot Peg Assemblies $50.00 SOLDdmmsouder
SOLD Fuel Pump/filter with hoses $50.00 SOLD FZ#1
SOLD Clutch Cable $15.00SOLD FZ1 in MIA
SOLD Carb Bank with Ivans MB Jet and PODs $200.00 SOLD skifffz1
SOLD OEM Seat (has one tear) $30.00 SOLD Bopropucope
SOLD Rear Sprocket is a +6 $15.00 SOLD Bopropucope
Currently have a deal in the works for the tank. It does have damage to right side. I can add you to first Dibbs if my current deal falls thru. Just let me know. I'll have photos this weekend
Thanks for the quick response. Unfortunately I already have damage on mine and am looking for a dent free tank. Thanks anyway though.
