Fz1 clutch cable swap.
Delta
Hi guys
I need some advice on the clutch cable. I have a fz-1 N 2006- on model. I have changed the risers and the metal bend in the cable near the clutch lever gets in the way.
Do any of you know of another clutch cable from another bike that fits and does not have that metal bend on it?
Could do with another 50-75mm to the length too but that's not important.
So just a clutch cable with out the metal bend and a bit longer if possible would be just great.
Thanks for any help guys
Delta
Dicko
Active Member
I know some people have changed the clutch cable, but I don't know what it was swapped out with.
Delta
Thanks bro,
I have got the length of the inner and outer cable now so I'm going to get one pro made and maybe 50mm longer too.
Delta
So it's not as easy as I thought buying a custom cable. They need length of inner and outer, size of nipples, size of any adjusters etc. Means I have to take mine off, then the hassle of putting it back until new custom cable arrives.
Have any of you fitted a clutch cable from another bike with success ?
Same length or a bit longer would be great.
Any ideas guys?
Delta.
