Delta
Ok so I've bought some nice cnc blue anodised foot pegs to bling the bike a bit. The rear pegs wasn't any trouble as you pull the cotter pin from the shaft that goes through the peg and swap the new pegs, easy!
Right the front, there's no cotter pin that goes through the shaft. It looks fixed..! So do you drill out the shaft and replace it with a new one that has a cotter pin or.....?
Have any of you had this little problem and if you did how did you get round it?
I'm thinking the only way is to drill the bottom the part that looks like a fixed washer or rivet etc.
Thanks guys.
Delta
Thanks guys.
Delta
