Givi PLXR rack + Graves FE + stock signals = ok?
Not really compatible with a FE. The rear portion of the rack kind of floats free so you may be able to use it. Now it all depends on what version rack you get. They changed the mounting a bit from the older one.
My bike is in storage about 15 miles away but from memory you can use the stock signals and stock plate light using their fender reinforcement but I'm not sure how it would work with a FE.
I'm running that rack + FE, but no way will stock signals fit on the inside of the rack with side cases mounted. Either have to use the signal extenders which come with the rack (uber ugly, but functional), or go with smaller signals or integrated tail (which is what I have).
